Hello folks, this is my first post and first time working on a Bass Tracker. I have gotten a lot of useful information on this site over the years but could not find the answer to my question. I'm doing some restorations on a Bass Tracker I purchased at a great bargain but didn't really need. It has sat for two years without me touching it and now I'm ready to use it or sell it but I'm fixing it up first. I had a mechanic come and check out the motor tune it up and it runs strong. I'm replacing the decking one section at a time. The foam under the rear casting deck has expanded and buckled the aluminum floor popping a few rivets. I drilled out all the rivets holding that section down, the foam under the decking is dry. I thought I would remove that section of the deck, remove some foam, rivet it back and then re-carpet. It's the left side of the boat and there is a hose going from the live well through the foam into the bilge area so it looks like I have to dig that hose out in order to remove that whole section of aluminum deck in order to remove the rest of the foam to get the decking flush and level. If you are still following me please correct me if I'm going about this the wrong way.
My question is since my foam is still good and I'm going to have to remove more foam than I initially though just to get the deck level. Is I OK for me to leave what is still good once I get that section of decking out and pour new foam on top of the old foam? Or do I need to remove all of the old foam and go new all the way? I hope all that makes sense. I'm going to attach a few pictures just so you guys have a better idea of what I'm working with. Thanks in advance for all your help.
