Re: Bass boat cap removal help needed
This is exactly the problem I have with my Glastron 175. The entire splashwell is glassed in on the interior of the boat and I cannot get to it in order to free up the cap.
A PO poured Seacast into the transom area, but failed to put the top back on correctly and then glassed it poorly as well. I honestly don't know how I'm going to get the cap off so I can fix the alignment properly, but am thinking of cutting the sides and back bottom of the splashwell so I can remove it and square everything up and get the top aligned again. I feel I have to get the top off to do it correctly. You can see I've tried to cut exactly where you are planning to, but had no luck in freeing things up because it is glassed underneath AND the Seacast has bonded to the inner skin.
I've been told almost anything can be fixed with new fiberglass, so I may just attempt cutting away at the splashwell.
View attachment 157365View attachment 157366View attachment 157367View attachment 157368View attachment 157369
Not sure what you mean by the cap not being aligned properly, but if what you are talking about is the third picture...
You can build up some layers of fiberglass to even out the joint, and fair in the repair...But, if you are also doing a restoration and trying to remove the cap...
Then, yes, unfortunately if the transom was poured sea-cast, that will tend to bond everything together, but you may still be able to separate the inner transom skin by using some prybars or putty knives, etc., although maybe not in one piece...sometimes you just have to get creative...but don't worry...
You are correct in the fact that if it is fiberglass to begin with, anything can be repaired with fiberglass...plus with the amount of helpful guys here...you can get it done...
I do suggest that if you are tackling this problem, you start your own thread here in the restoration section of the forum, and you can get a lot of help from the guys here...if you have already started your own thread, add it to your signature, so we can get caught up with it...
Hope this helps,
GT1M
