thewallflowers
Thread starter- Joined
- Apr 1, 2021
- 19
I am tracking down why my old starfire wont start. i am only getting about 5 volts to the starter switch and gauges. It looks like someone prior to myself made an attempt to rewire the dash as all the wires are either red or orange. I can not find any info on the ballast resistor as it seems to be in the mix of wires. it is connected to the solenoid where the battery connects and is getting only 5 volts where i think the resistor is. it looks like a gob of glue around a blade then a wire comes out of it. The OMC book shows' it but has no info on it so how do i tell if it is bad? I can jump the new solenoid and turn over the motor and if i jump the coil i can start it. with the key on it will stay running after i take the jumper wire off until i shut off the ign switch. any ideas??
