Re: Baitwell pump not working 2006 model 2002
well, on the 2004's its down in the center hatch between the seats, where the batteries are, open the hatch, stick your head down inside and look to the stern, it should be up on a bulkhead. I'm lucky...I stand 5' 2" and was able to actually get down inside that compartment and disconnect and install the new, it was tight but do-able. easy install once you get to it, just get one that has the same configuration and mounting and it's basically a swap. I replaced mine with a Jabsco Par Max 4 model 4.3 gal per min. I forget how much $$ it was but its been working longer than the org. I have the Pro package and it comes with a raw water was down so it handles my livewell as well as my wash down. Like I said, I've got a 2004 so hopefully it will be the same.
http://www.solunar.com/Jabsco-Par-Max-4-Washdown-Baitwell-Pump-P19631.aspx this is the one that I bought to replace mine and it worked perfectly. Hope this helps you.
