watersportsguy
Thread starter- Joined
- Jul 16, 2011
- 10
Howdy,
I am posting here as well as elsewhere. I have basically a PWC with a hull. It is a Four Winns Fling. OMC 115 HP , 4 cyl, 2 stroke 2 carbs with a turbojet drive. I have been having fuel contamination issues since I bought it. Collecting fuel/oil mix from output of fuel pump shows water at bottom of glass jar. (electric fuel pump and VRO with oil tank).
So I purchased a Moeller Clear Site (10 micron) fuel/water separator. Installed it after the primer and before inline fuel filter.
(gas tank....diaphram primer.....SEPARATOR...filter...pump). Primed it and cranked with carb hose disconnected to check operation. A few ounces of fuel came out then nothing. As I turned over the engine I noticed fluid collecting in the bowl at the bottom of the separator. Drained it and let it settle in a jar. It looks/smells/tastes (kidding) like straight gas.
Pumping the primer ends up with gas getting dumped into the bottom of the separator. Nothing is coming out of the separator's output. Pulled it and screwed on a spare filter. Tried blowing air through the assembly. worked Didn't notice the pressure required. Is this filter too "restrictive" in this setup?? Need to get the moisture out.....how though? Newbie to marine mechanics.
Thx
Thx
