Haut Medoc
Thread starter- Joined
- Jun 29, 2004
- 10,645
This is a '73 Mercruser 888.....
I had it running in the driveway, shut it off & when I came out the coil was hot & leaking oil....
I replaced the key swich & slave solenoid after determining both had failed.....
Now, on to the problem at hand....
After this incident, I put on an old coil that came with the boat, it is marine & says use a resistor, (It actually has 'Mercruiser" printed on it, I suspect it is the original...
Anyway, I now have 12v at the coil.....
It should be 4-9v, running or not, correct?.....
Is it possible to fry the resistor wire so that it loses resistance?.....
Are these resistor wires still avaiilable?.....
It is an auto part or a marine part...
I could easily run a new wire bypassing the harness.....
Any help out there?.....
