Baffaled
Gbradley
Truly at a loss everything worked prior to winterizing I unwrapped the boat replaced a bilge which is working fine Toggle switch on the navigation light lights up but light does not work replaced bulb still doesn?t work don't know where to go from here all wires look secure. Same with the horn it?s a little wimpy and all though I most likely carry an air horn can?t figure why it won?t work either.
1980Galaxy
Re: Baffaled
could your battery be dead? near dead? get a voltmeter and test your battery. less than 12.6v is bad but wouldn't be surprised if its alot less.
