rodknee1231
Thread starter- Joined
- Jul 28, 2015
- 136
Just got my power head put back together (73' 135hp) some of you might be fed up with all my posts but im on the cusp of having this old girl 100% i was running on muffs the other day for the first time and i noticed i could on hold my finger on the head for a few seconds. Thought that was a little irregular. On top of water coming out of the seam of the lu and the midsection which ive narrowed down to a bad exhaust seal. I shut it of and checked the water pump(brand new kit) all looked good. So i moved to the vernatherm and pulled it and tested it. Slowly it opens in hot water. Then after a min in room temp water i pull it put and it closes but takes some force. Is this normal or should it close much easier? Also i added a tell tale it was peeing and kinda stopped before i shut it off would the therm cause that ? And am i right in thinking the leaking exhaust seal would be causing water to come out of the seam between the lu and midsection?
