saltwaterbluefish
- Dec 14, 2010
- 156
1977 115 HP Johnson 115EL77S
As I was coming back from my favorite fishing spot, I decided to stop momentarily to check out another fishing hole. Was there about 15 minutes and when I went to crank up, nothing. The only noise was from me pushing the choke in on the switch. After pulling the cover, the engine and starter were a lot hotter than normal. After limping back almost to the dock. I was able to get her to crank and limped in the rest of the way. However, while waiting to get her on the trailer, she cut off again. After finally getting it out of the water, I started diagnosing the problem. When I pulled the hot wire off the starter, i noticed the entire pole on the starter wiggled. Problem #1. After doing some more checking, I also found that the solenoid went bad. Problem #2.
My question is, could it be the loose starter pole that caused the motor to get hot or could it be a larger issue that is starting to develop? Will a bad solenoid cause it to crank when cold and cut off when hot?
I installed a tale-tale on her 2 years ago (Thanks iboats for the DIY) and she is peeing good, so it does not appear to be a water pump issue and compression is running around 90 psi on all 4 cylinders. RPMs are around 1200 at idle and no jumps or sneezes. Just being cautious as I don't want to have to limp back, especially on days when there is no wind, current going in the opposite direction and the temp is in the upper 90s. Of course having i-pilot is a lot better than a foot control when you have to limp back.
