Bad news? Engine compression.
AFishin69
Re: Bad news? Engine compression.
Thanks Walker, although I took the prop off and took a closer look. The leak is coming throhg the inside of the prop where the exhuast is. It is free flowing and it comes out as fast as I can pump gear oil into the Mother Fu**^$ Do you guys think you have any guesses to the specific point that it might be coming out to save a lot of trouble. What does the seal kit contain? I heard something about I will be in trouble on another post.. if the seal is busted in the and yo have to machine it or soemthing?? Any guess I am all out. I am about to surrender and buy a new motor. <br />Speaking anyone interseted in selling any motors?? Than run fine?? I think I can come up with about 2,000. Any offers I am all for it thanks guys you ahve been such a hELP AND i HAVE LEARNED SO MUCH!!
foxjohnc03
Where are you located AFishin? I would be interested in purchasing your 135 if you are looking to get rid of it. Send me an email at foxjohnc@comcast.net.
SeaMasterZ@aol.com
just go on ebay and get another lower unit<br /><br />they sell them quite reasonably<br /><br />I got a whole parts motor with a good leg for 50 bucks<br /><br />just keep looking!<br /><br />good luck
93bronco
Ensign
i would do a de-carb atleast 2times, check comp and if still low pop the heads off for a look sea & replace with new gaskets after heads were checked for staitness. redo comp and go from there. to early to start giving up- to get another motor with the same if not worse problem.<br />-<br />you have got some one trying to buy it now, that should tell you a little something.
