clemsonfor
Thread starter- Joined
- Sep 19, 2005
- 1,011
Ok here is the usual question, i could not find my answer on old posts so here it goes. I have a 74 evinrude 25 long shaft. If i find a compatible yearmodel but in short shaft, i aleady know i use my water tube extension, driveshart and so on, my real question is the shifter? Dose is easily remove from the unit if i find a short shaft replacement or will i need to have it cut and a 5'' peice welded in?
Also what year and HP ranges will fit this motor? i found one off a 1957, but i assume this one will not fit.
