So i bought a used boat 1985 Century Bronco I w/ 3.0 mercruiser Alpha I Outdrive. Tuned up motor (though carb needs rebuilt due to rough and sporatic idle), removed lower end on outdrive and replaced whole water impeller system, put together 3 times (simple rookie mistakes) and finally filled with fluid (from bottom up with handpump) and then pressure tested to almost 35 psi. No problems other than vibration in whole boat while idling, took to lake about 4-5 times and ran like a champ. However, we have had a drought this year and like a rookie ran with the outdrive up farther than i should when pulling to the boat dock, cause it would start to hit bottom if i didn't. Still no problems UNTIL i took it on a long trip to Michigan and ran the boat HARD wide open for many hours. Ran around 4400 rpm at around 37 mph and I turned very sharply, then back straight at the end of the day and as i was backing off the throttle the outdrive started Randomly 'banging' very loudly like someone was hitting it with a sledgehammer. I backed to neutral and the sound was still randomly going on, so i shut it off and checked around the unit couldnt see or feel anything and checked the prop would lock as supposed to in and out of gears with engine off using shifter. At that point i tried to start and engine would start, the banging would randomly happen and as soon as i touched the throttle or put it in gear, the motor would abruptly die. I pulled the whole outdrive off the back and it was very hard to pull the unit off the last couple inches. I got the unit off and there was some (maybe a cup) of water in the u-joint bellow and slight rust coloration on the shaft and u-joints. The gimble bearing was replaced (supposedly) 3 years ago. I could see the corrosion was coming from the shift cable area and also around the water intake tube ring (lots of corrosion and crud). The lower end unit looked great when i had it appart before the issue and can turn the driveshaft by hand and make everything function in fwd, rev & neutral. There is slight slop trying to turn the driveshaft (inside the unit-not the driveshaft slop) to make the prop spin, but not much.
Sorry for the long post, but needed to give history!
My real questions:
The gimble bearing seems like it is rougher spinning than it should be, so i plan on replacing that, plus the vibration the boat had always at idle but lessened the faster you went.
The U-Joints even though they aren't so tight that the joints hang by themselves, have NO slack in them at all, still have white grease leftover from the last time the grease fitting was used. The U-Joints move super freely and i mean with little effort you can move it around without restriction, but can't find any information online of how to test to see if they are bad, as i said NO Play in anything u-joint related. I don't want to replace them just because if they are still good. I am not comfortable pressing them out and even less about removing the main fork out of the unit.
I am getting ready to order bellows kit, gimble bearings, alignment tool, installation tool, gaskets and all.
Do i need to get a new cable? It shifts fine, but appears the leak was from the place the cable fitting goes into.
Will replacing all of the bellows get rid of the leak around the shift cable?
There are no nicks inside the gimble housing or signs that there was 'banging' going on in there.
Again, sorry for the long post better to have too much than too little.....
My real questions:
