This past weekend i was out on my boat for a good three hours... on my way back to the dock a few larger boats flew by making some larger waves as i (in my 18' 2000 Stingray RS) was going a good 25-30mph, i hit some of the waves hard and then about a min or so later i noticed that i had the throttle down almost the full way and it was only going about 10mph. (when realisticly it shoudl have been going a good 30-40mph) It almost sounded like it was not accelerating after a certian point. I knew that on the way back that if i cut back on the throttle the engine would stall. I got close enough to the dock to test that out and then brought the throttle down and it indeed stalled. I started it up again and it was still running rough but not as bad. I noticed that it was stalling when i was not having more pressure on the throttle. I ended up trailering it back to my driveway and ran it after i hooked it up on the hose. It seemed like it was running normal again but i think that i might have gotten bad gas or had a water pocket burst in the tank when i hit that wave. ANy ideas?
The motor is standard for the boat: 135hp Mercruiser i/o
Thanks
Thanks
