christians89
Thread starter- Joined
- Jan 13, 2011
- 55
Intermittently the motor will die from a high rpm down to about 1500rpm and will not go any higher. Sometimes it does it from a cold start or while your already running down the lake. I know its not a fuel problem. Ive cleaned the tank, carbs have been entirely gone through, and while the problem is occurring if you squeeze the primer bulb or hit the choke it just makes things worse and the engine usually dies. Ive also tried unplugging the temp sensor while the problem is occurring but there was no change, was thinking s.l.o.w. Ive tried remedying the problem by closing up the plug gap a little and this made the problem go completely away for about a week or two, but now its back and its getting worse. This is whats leading me to believe its the coil. What do yall think? Thanks in advance!
