Thanks to you all! I followed your advice, compression checked very good, so I went back into the carb and sure eniugh, the idle jet had a piece of crap in it. Blew it out and problem solved!!! Now I have a new question. I replaced the water pump on general principal (no knowledge of previous maintenance habits). There are two drains - one from a small tube that runs from the block to the bottom rear of the cowl. The other is an impressive hole about 12" below the engine. On startup, a stream of water comes out of the small tube and a spray from the big one. After about 2 minutes of operation, the stream of water stops from the tube, but the spray continues from the large one. After finally gettingthe motor to idle last night, I let it run for about ten minutes. The water spray was not hot and the motor was not hot to the touch. Is everything OK?<br /><br />Case<br /><br />Work is for people that don't know how to fish...<br /><br />
