Back flushing?
Laddies
Banned
Re: Back flushing?
If your talking about fresh water flushing after use in saltwater just buy a set of muffs and hook it to a hose and run it for a few minutes
imported_Bluefin
Re: Back flushing?
I think that my cooling system might be plugged up and I was looking for a way to force water through it to clean it of debiris.
Laddies
Banned
Re: Back flushing?
About the only thing you could do is remove the hose for the telltale at the block to see if thats whats plugged, is the engine overheating, with a good impeller you can not back flush and I doubt if it would do anything any way. If its plugged up myou will probably have to remove the exh. plates and the cyl. block cover
