I asked this question on the bottom of another post and I am still hoping for some clues to what I did wrong.
When I removed from the gearbox the drive shaft things were fine but during the night the gearbox fell a couple of inches which turned the prop.
Problem is now I cant get the shaft back into the box.How much force is required or can the gear that takes the shaft move out of alignment with the hole for the shaft.
How do I fix this,after all this work the pump housing and impeller are like new.
