B100S clamp lever - replacement part?
one4fun
I have a Honda 10 hp outboard - serial number: B100S-1600710. The two clamps that are used to mount the motor have broken - specifically, the handles that you hold onto when screwing the clamps down.
Are these still available? Will clamps from another brand of outboard work? I am not picky about color or matching them together - I just want two of them that will work with my motor.
Thanks.
one4fun
Re: B100S clamp lever - replacement part?
Well, I will answer my own thread with a solution that I came up with...in case anyone else finds themselves in the same boat. (Yes, I really just said that) :facepalm:
Less than $10 invested and about 45 minutes of my time to make these. It seems that the Honda ones are hard to come by (still $20 each) and the Mercury ones would run about $30-40 EACH!
1/4" all thread
4 - 1/4" flanged nuts
aluminum tubing - 1/4" ID
4 - 1/4" cap nuts.
I drilled the holds out slightly in the clamp screws to fit the all thread.
Very straigh forward - and it is easy to use, clamps tight and I can still use my locking bar that goes across the clamp handles to lock the motor on the boat.
