Avatar
Kiwi Phil
Assuming I have got this correct and the Avatar shows up, has anyone ever used this one before.<br />Cheers<br />Phillip
Kiwi Phil
Re: Avatar
Ok...Ok.... all you Larikans that can do things "1st" up :D , how about a little help.<br /><br />1).I R clicked the url on the Avatar picture I put in Photobucket.<br />2). I opened "My Profile", then "Edit Profile".<br />3). Went to "Select a Different Avatar" Image and opened that.<br />4). Went to "Use Custon URL" and deleted that<br />5). R clicked my "URL" from Photobucket and R clicked and "paste" it in slot.<br />6). L clicked "Set URL"<br />7). Then my Avatar appeared in the top L hand blank box, and when I went back to "Edit Profile", it was in the once blank avatar box<br /><br />So I have it in the right place.....don't I?<br /><br />I have just done it again, and it is in my Edit Profile", so lets see what happens.<br /><br />If I have missed something, please spell it out in simple language for me and I will try again.<br /><br />Cheers<br />Phillip
Kiwi Phil
Re: Avatar
OK, so that dosn't work. <br />Have re-checked my "Edit Profile" and the picture is still in the Avatar 'box'.<br />Heeeeeeelp<br />Cheers<br />Phillip
heycods
Re: Avatar
Its majic , all the sudden something works right and its there. I was using PB to post pix on another site, one posted and I could never do it again.Everything has to be exactally right, your missing some little something.
SpinnerBait_Nut
Re: Avatar
Phil, when you get done with your profile, scroll to the bottom of the page and click on "Update profile" and see if that works.
Kiwi Phil
Re: Avatar
Thanks Lester. I have done that. Hopefully all will be fine this time.<br />If this avatar shows, can you recall anyone using it before, (and what it stands for).<br />Cheers<br />Phillip
brother chris
Re: Avatar
Kiwi Phil.....I have never used a green fish letter opener in my life, but thanks for askin. :p
Reel Poor
Re: Avatar
Well.....Were gonna need a bit of a nudge in the right direction. :confused:
Kiwi Phil
Re: Avatar
It was used by a Naval Military unit, quite large, about 65 or so years back.<br />Cheers<br />Phillip
