Automatic Choke
crazyhousewi
Whenever starting cold I have to remove the cover and manually choke the motor, which starts immediately. Do I need to replace the choke or is there a trick I don't know about?
chuckz
Re: Automatic Choke
Pressing in on the key should activate the choke solenoid and keep the chocke closed as long as you keep the key pushed in.
rev.007
Re: Automatic Choke
i have the same problem,i called the marine dealer<br />and was told my carbs were gummed up.that not true<br />because i had all three rebuild last fall and maybe ran the engine 3hrs.i also put stablizer in <br />the gas.as long as the motor is warm it will start fine. but cold i have to pull the cover and manual choke it.any body got a solution.
WillyBWright
Re: Automatic Choke
Welcome to iboats.<br /><br />No such thing as as automatic choke on a Force. Push the key in and it's choked. Let go and it's not. Does it choke when you push in the key? The solenoids are touchy and if far enough out of adjustment they won't pull the plunger.
rodbolt
Re: Automatic Choke
hello<br /> could ya kinda give us an idea what HP and year this is ?
roscoe
Re: Automatic Choke
Welcome Heyoldguy and rev.007.<br /><br />Please always post make/model/year info.<br />Could be faulty solenoid/actuator, faulty ignition stitch, loose wiring, or operator error.<br /><br />Let us know what you have.
rodbolt
Re: Automatic Choke
hello<br /> in 99 it used a push to "choke" switch. however I belive it actually uses a fuelprimer solinoid rather than choke plates. with the key on engine off and hood removed push the keyswitch in and see if it clicks. if it does have a set of choke butterflies then see if it clicks and the linkage moves.<br /> How are you manually choking the motor ?
BaysideMarine
Re: Automatic Choke
If your engine has choke butterflies then it is absolutely essential that when the choke is operated the butterflies FULLY CLOSE.<br /><br />In Chryslers of old if the choke butterflies did not fully close then there was NO HOPE of the engine starting.<br /><br />Of course manually choking the engine (with the lever at the engine) or hands over the carb intakes would get around the problem of a lazy choke solenoid.<br /><br />Cheers,<br />Nicholas
rev.007
Re: Automatic Choke
to answer your question the best i can.first it<br />does not click when you turn the switch on.<br />second there is a little push button switch on the right side of the motor left hand side if you are on the ground.push the black button down<br />and it will start.i have ask the same question about a clicking sound.you are suppose to push the switch key in to choke but nothing happens.<br />i feel that the marine dealer is just trying to run up another bill on me.i bought the boat and motor new in 1999.i haven't had a good season yet.<br />mercury will not offer any help at all.it is like <br />tough.i really appreciate any help.
roscoe
Re: Automatic Choke
give us a little time, someone will come up with the answer for you.
Gonfshn1
Re: Automatic Choke
Start Simple! Check all conections. clean with contact cleaner and go from there. The marine enviroment is tough on wiring. espesialy those that are exsposed.
roscoe
Re: Automatic Choke
I am having a little trouble understanding what you mean by the " little black button on the side of the motor."<br />I know there were some changes made to the 1999 models, but this black button is new to me.<br /><br />Is it on the carb?<br />on the throttle linkage?<br />the starter relay?<br /><br />When you turn the key to start, the starter should engage and spin the motor.<br /><br />When you push in on the key, there shiuld be a very quiet click coming from just behind the carb. This would be the sound of the fuel enrichment valve opening.<br /><br />For starters, please describe the starting process you are using, in detail, from hooking up the gas line to getting the motor running. You may be missing one small but important step.
rev.007
Re: Automatic Choke
that would be the fuel enricher button that i was refering to.without mashing it the boat want start
roscoe
Re: Automatic Choke
ok, Since I haven't actually worked on a Force that was newer than 1996, I wanted to be sure we were talking about the same thing. There is no black button on the older models. Be glad you have that manual override button, none of my 6 motors have one.<br /><br /><br />So, the fuel enrichment valve is not opening when you push in on the key. Could be a faulty ignition switch, the wire may not be connected to the ignition switch, a bad enrichment valve, or a loose or broken wire at either end.<br /><br />A simple check for voltage on the yelo/black striped wire should tell you if the signal is getting to the enricher. Also check to ensure the solid black ground wire coming out of the enricher is attached at both ends.<br /><br />This should be an easy fix and any dealer should be able to work on that motor and get her running. Perhaps it is time to check out another dealer, or an independent repair shop.<br /><br />Anyway, check out that wiring. You can use any $12 circuit tester from Radio Shack, or even a $3 test light from the hardware store.
rev.007
Re: Automatic Choke
i posted a report a while back that my 75 force would not start cold.after paying out close to a thousand dollars to have it worked on the only thing was wrong was a wire was unpluged.it runs great now.i finally fixed it my self in the driveway.so much for trust.
roscoe
Re: Automatic Choke
Glad you got her fixed, sorry it cost you the dollars, but it cost the service guy your trust. That will hurt him in the end.<br /><br />happy boating.
