Re: Auto Blend, Trustworthy??
Jerry - FYI, the math is, one ounce oil per 50 ounces of gasoline. Each gallon of gasoline = 128 ounces. Each qt. of oil = 32 oz.<br /><br />IF you end up pre-mixing (I'm not saying whether you should or shouldn't), I'd advise setting up a pre-marked container for measuring oil according to the number of gallons you add. It can be a ready-made measuring container that you can find in stores, or get yourself some sort of appropriate size clear plastic container. It doesn't have to be a measuring container, but just one you can make permanent marks on and with a tight lid so that when you store it on board, it won't make a mess. Put marks on the container for the amount of oil you'd need for certain numbers of gallons of gas (e.g. 1-22 gal). It is my opinion that this doesn't have to be super-exact. Round to the nearest ounce of oil for your marks. When you add gas round to the nearest gallon. Don't get into micro-measurements.
