waterboy84
Thread starter- Joined
- Nov 25, 2015
- 98
Quick question. I bought a boat and the radio that was in the boat did not work.
Hell the radio was so old it was the radio that had a tape deck on it.
Anyhow i went and bought a new radio with cd player.
No i didnt get a marine radio becuz where the radio was installed there is no possible way for it to get wet. It sits behind a water proof sealed cover box and that sits behind a glove box compartment.
Anyhow. Question is.
If i run a direct power wire from the battery
And if im not using my boat is the radio still pulling charge from the battery even though the radio is off.
Reason i ran a direct wire from battery to radio is becuz the factory wires that are there already for some reason i can not get any power from the factory wires. I tried everything ffrom new fuses in fuse box to running a new wire from the fuse box. And yes i had they key ignition turned to on position when trying to turn on radio and nothing. But a direct wire from battery radio turns on.
To leave the radio set up with the direct with from battery. Should i inatall a toggle switch or by turning off the radio is ok.
Sense i installed the radio by running the direct wire from battery i have had to have my battery charged twice.
I never had this problem. I could leave my boat sitting for weeks at a time and battery would not be dead.
Im thinking with having the radio hooked up directly to battery the radio is continuously pulling juice from battery.
Im thinking a toggle switch to cut off all power may fix the issue of battery being drain. Just would like to get some input on this before doing anything else.
Thanks. All info is greatly appreciated.
