Audio question
merleti
I'm working on completing my sound system on my boat. I just have a basic system with 2 6-1/2 coaxials mounted in the center console of my boat. I'm about to add an amp and was wondering if putting in enclosures for the speaker would help? If so what type of box and size would you use on them for full range?
Re: Audio question
You are on a boat not a concert hall so whatever you do will not provide any significant benefit other than protecting the speakers. Enclosure size will be limited to the space you have in the console.
merleti
Re: Audio question
Thanks. I figured if I was going to spend that much on a system I would make sure I'm doing it right. Thanks again.
Utahboatnut
Re: Audio question
I would tend to disagree a bit, any time you enclose a speaker the sound you get out of it is much improved. You lose alot out of the back of an un-enclosed speaker, even a 6x9 in a decent little box will sound much fuller, louder and perform better. You arent in a concert hall I agree but with just a few speakers like you have you need to get everything you can out of them..
bouttime007
Re: Audio question
My thoughts exactly.
Fabbing up a speaker enclosure will improve the sound a little.
Sparke
Re: Audio question
I am thinkingabout adding a amp to my boat as well, what kind did you end up buying and how much?
Thanks,
Sparke
chrclo
Re: Audio question
I agree, having the proper enclosure if you can makes a big difference. For the amp you have to look at what you are powering. Are you adding a sub or just powering the 6.5's. Stick with quality name brands kicker, jl, fosgate, jbl, sony, hifonics, crunch (i like this one for value). Stay away from unknown brands. Some of these brands are more expensive than others but all are good quality and some even competition level. the 12volt.com and diyma.com should help you out as well.
