coolguy147
Thread starter- Joined
- Jul 14, 2008
- 2,817
welllll, i've been driving my head crazy and doing anything possible on this thing.
check compression....littler over 130-135 (cold)
has 570 miles on it
cleaned carb twice. (every nook and cranny. took over jet out. even main. couldn't get the seat out though? maybe float height is too low allowing not enough fuel to be brought in?)
i messed the pilot adjustment screw but i set it to 2 3/4 out. it's been all the way to 3 1/2 out and it still would act lean.
adjusted intake and exhaust valves twice. the first helped a little.
took carb to engine boot off to clean gasket and applied some anarobic sealant. no help
sprayed brake cleaner alllll around boot to look for air leak but didn't help
my atv is running lean! but i don't know why!?!?1 the atv has noooooo mods.
i get a backfire though the intake and if i throttle up then back off it will backfire through the exhaust.
i ran the old gas out and ran new gas in(cleaned carb again after old gas was gone)
jets have been left alone. when it was running good it was great then it would stall after a while. barely though. then later it started to get a slight backfire through carb.
also, it has a weird problem of like dying for a second then coming back like a intake backfire but not pronounced. after a while i stopped using it as much and it later would only run with the choke until i cleaned the carb
basically my problem is i don't know why but it keeps running lean?
tomorrow i'm going to open the intake valves just a hair incase i got them too tight.
has 570 miles on it
