mystro
Thread starter- Joined
- May 2, 2007
- 142
Originally Posted by Silvertip
You are correct in that there are two versions of the PD with the black, pointy head. You can tell the difference by the deploy mechanism. The V2 has a handle that you push down on to pop the motor overboard. The original version had a loop style handle. Steering response is slightly faster on the V2 (I own both). Otherwise the motors are quite similar in both the autopilot and universal sonar. I have no issues with either version. The V2 also has a small, round connector for the foot pedal whereas the original PD had a rather flat looking connector. The pedals are different and not interchangeable.
Thank you Silvertip!! I'm hoping mine is the PD version which I can update to the the AP especially after reading ST's post above. I'll post a link to picture's since I'm confused which I own (newbie owner and no manual) ..fingerscrossed
http://picasaweb.google.com/highpurity/MinnkotaPd?authkey=4YWoYupfDsY&feat=directlink
thanks for any help
