Sea Rider
- Sep 20, 2008
- 12,345
BB, Is the Bombard X2 a Rib or Sib watercraft ?
Gluing back just visible unglued portion will be just a temporal repair, as the side rubber holder portion will fail soon after. Worst if inflatable is used non top inflated to its recommended working preasure along with a 4 strokes OB. Doing it properly is time demanding and costly if sent to a boat repair shop. My techie uses a industrial heat gun to remove transom from holder and holder from tube, but he has 25 years experience repairing all kinds of Ribs-Sibs and that makes the difference with respect to one who has never done this kind of repair before.
Better is to use Tuluene to open and clean other glued part as opposed to a heat gun. If that Bombard is still in good overal shape, fabric is not dried, cracked, just with minor patches you should repair it well, will have years of boating fun.
Techie tells me you should look how well is upper transom glued to support, could look mint but with probable dried/hardened glue issues already unseen to the eye. Try to peel upper tap portion with hand, if peels off with no sweat, bad music, must do 4 sides. If the glue you have ordered does not stay flexible once dried on glued parts, it's no use..
Happy Boating
Happy Boating
