dzurinko
- Apr 12, 2013
- 65
Looking for some input for re-attaching my trim unit to the transom. The tinny I bought needs to have the transom replaced. Attached to the transom was a hydralic trim unit. The motor was secured to that. I removed both trim unit and motor today. After re-flooring, painting, etc, I will be re-attaching both in the future. The trim unit was secured through the transom with 4 bolts. I'll do the same. But the existing holes are basically the same size as the bolts. It looks like the PO used some type of putty on the threads and large washers before tightening down. Is this an acceptable practice when I eventually re-secure the trim unit? I think Ive heard some others say to drill a larger hole, fill it with something (don't know what) then redrill back to the size of the bolts. Which practice is recommended? What product do I use to make sure these holes dont allow for water to infiltrate the wooden transom?
