ATF tip of the day
bigdee
I recently learned a tip from a auto detailer. Rub ATF on headlights to make them look new...it works!
I also use it on tail lights and plastic trim. Not permanent but holds up for a good while. Just wipe on and wipe off.
JRJ
Re: ATF tip of the day
Hadn't heard that one. Have used toothpaste to polish scratches out of headlight lenses with success.
Fleetwin
What kind of ATF?
There are a bunch of ATF's out there, all with significantly different qualities and applications.
I NEVER use anything but OEM ATF, I've seen too many transmissions fail due to WRONG fluid.
bigdee
What kind of ATF?
I used what I had laying around. I don't think my headlights cared!
Don S
What kind of ATF?
LOL, Obviously you didn't read the tip.
lakelover
Here's another ATF tip: use it to lubricate your bicycle chain!
bigdee
Another: mix with equal part paint thinner to make a good penetrating oil. Using it for headlight lens restore is really amazing.
gm280
I'm sure it would work until it wore off because it fills in the imperfections that make the plastic lens look foggy. But be careful what you put on those plastic parts because some fluids would simply dissolve plastic parts...brake fluid comes to mind. I use polishing compound (any brand will do) and a buffer on a drill. You would be amazed at the new look you can achieve doing that... That IS exactly what those headlight kits have in them, a polish compound and a buffer pad. Just buy the polish of your liking and use a drill buffer pad...a lot less expensive and accomplishes the same results.
bigdee
What I have found with those polishing kits is they remove the UV coating so the newly restored finish quickly fades. The ATF does not require any elbow grease, takes about 30 seconds to apply and will last quite awhile. I re-apply every other car washing. I also use it on all my black plastic trim. I have doing this for about a year now with no adverse effects. If extremely cloudy,instead of the polishing technique I think I would buy new lenses from Rock Auto.
PiratePast40
Mix it with a light oil and it makes a good gun cleaning solvent. Just be careful around your polymer parts.
ehenry
Rub ATF on teak wood that needs freshening up.
lakelover
depends on how you ride but typically that attracts way too much dirt.
It suits my riding style, surfaces and maintenance schedule. I recently read about it and am trying it to compare to other things I've used.
Nandy
I use it in my transmission... ;-)
bruceb58
I typically use TriFlow but I am a serious rider.
lakelover
I know of Triflow and I'm sure you are right. I would call myself a regular "recreational" rider, I just try to do it regularly for the exercise benefits and fun. I think I read about the ATF on the Sheldon Brown website.
:eek::eek::eek:
