djzyla1980
- Jul 26, 2005
- 640
Re: At Wits end with this one...think it's shop time...For the 70' 115
Ok.. to update on this problem I have. I rebuilt the carbs today and put the puppies back on. I also took a good look at my throttle cable and decided for the $26 it could be changed... to rule out another might be. Got it put back together and this is what I have now running on muffs in driveway.<br /><br />Idled great although there seemed to be a miss every minute or so. After about 4-5 minutes of ideling it would miss then die, start right back up and do the same. Pulled the plug wires one at time to see if there was any change and there was Absolutly no difference with performance no matter what plug wire I pulled. <br /><br />Idle seemed much smoother since rebuild but with a miss.<br /><br />Pulled plugs and took a look and all plugs were the same. looked a bit wet to me though. Loading up maybe? <br /><br />Shoved her in a trash can and started her up. Would not idle worth a damn unless I was sitting back at the "right off the start saftey switch" area and still that wonderful miss. Move the throttle 1/8" and I'm past the starting point. While in the can I decided I would bring the throttle up a bit and see if the miss stayed and it did but was more definate. Like a plug was fouling...then would kick in for 20-30 sec and then foul again. The more I brought the idle up the longer the plugs fired before the short period of miss period of miss. It is definatly not fluctuations in the fuel. It's got to be the ignition. <br />Swapted plugs-no change<br />Pulled Wires one at time-no Change<br />Clean/regapped plugs-no change<br />Spark test showed OK believe it or not..(got's me confused as well)<br /><br />Is it worth me to look at the gap of the Sensor coil under the distributor or does is act like it's something else?? Am I loading up and thats why theres this miss and how do you solve this one?<br /><br />Another thing is why am I playing at the line of the start saftey switch? I think I should be able to idle well below this point. I can get my cables and linkage to move in that direction... Just WILL not start.<br /><br />Any help or ideas would be appreciated
