djzyla1980
- Jul 26, 2005
- 640
OK...Last week I took the boat out... Finally got it to run WOT until it just died. Thought it was a sheard key but find out it is a rotor issue. (tab on rotor was broke so it wasn't keeping time) <br />Another thing I had a prob with is cavition or ventilation (not sure which one)with the prop unless the motor was at closest to boat setting.<br /><br />Took the boat out tonight after fixing the rotor issue and Plugging 8 holes on the cav plate from tabs or whatever else they could have been there from.<br /><br />Idles great. but Absolutly no power at all. For the life of me I could not get the thing to open up. Just kept bogging down and no mater what changes I made (lync and sync, throttle adjustment, idle adjustment, trim adj)Checked spark... good on all 4, gapped plugs and regapped, pumped primer bulb no change, Choked engine/engine dies <br />Got the holes filled in and with that I could move the pin farthest from the boat or closest with no problems as before. So I believe the reason I had vent/cav prob was from the holes and not the prop. Moving the trim had no effect on the motor in any way.<br /><br />A 115 on a boat that weights less than 1400 (manufacturer says 900 in 72) if you add the 500 lbs for the kids, wife, cooler and I your lookin at around 1900lbs... this boat should move along pretty fast... something is wrong.. and I don't know what it is. I really do not know what else I can do to this to get it running right. I don't understand why the only thing you change is the rotor and everything is messed up again. I believe I probably have an adjustment outta wack, but i've gone over and over the manual and checked and double checked. I'm at my wit's end and the only thing I can think of is to take it in. Wife told me to take it to the shop... and Thats the plans if theres not a fix out there quick(have to jump on offers from wife like that). I just don't like takin them in cause I feel they nit-pick at what is wrong... as in finding issues that have nothing to do with the reason it's there.
