New member here....I am doing my very first boat restoration project and am learning as I go. Here is where I am at thus far...
1. All hardware removed including windshield
2. Interior removed and discarded
3. Gel coat cracks ground out and filled with short strand filler
4. Entire topside sanded with 80 then 120 grit
5. 3 Golf ball sized holes repaired in top side
6. Fibreglass removed from Transom top (due to cracking and delamination)
7. Transom inspected for rot (fortunately it is ok other than the delamination)
8. Transom repaired and re-capped with 5 layers of cloth
9. All holes (from bimini and bow cover) filled
I think I am ready to start the painting/gel coating process and have a few questions.
I have tried rolling and tipping new gelcoat and am not happy with the results. I have since purchased an HVLP gun and have sprayed a test area. I am happy with the sprayed application, but it has virtually no gloss. I am wondering to what extent I will have to sand/polish to get a nice durable hi gloss finish.
I am now thinking of gelcoating the bottomside using a 1:1 mixture of gelcoat and duratec hi gloss additive as this area will be subjected to under water use.
As for the topside, I am looking into Interlux brightside sprayed on.
Has anyone had experience with either method or both methods? I am obviously looking for a nice quality long lasting finish with minimal sanding/polishing.
I am also curious where a guy can get reasonably priced rub rail?
The boat is a 15.5 foot 1975 Princecraft Tri-hull with a 1980 Johnson 115 hp outboard.
I appreciate any help/advice you guys have to offer....
I purchased the boat/motor/trailer for 500 bucks so I can afford to invest a little in fixing it up.
