Fzy1
- Jun 6, 2011
- 22
Where do I start?
Neighbor came to my door and asked if my brothers were still interested in his boat.
Arrow Glass Cougar, with 1979 70HP Mercury, and trailer. Price 250 dollars.
I said screw my brothers I want it at that price. We proceeded to move over to my yard. I began to look it over. It was dirty as can be so my nephew, and niece began to clean.
Today I removed the seats,
One seat needed the bolts ground off. It was not close to the centerline at all. It looks to have had a hole drilled down into the stringer for the base approximately one inch in diameter. In the hole was mush. I then removed the captains chair and passenger chair. Once I had them out of the way. I removed the plywood sheeting that was screwed down into the deck.
This is what I found:
The more I pulled, and cut the uglier it got.
Now I am at a crossroads. do I remove the guts;(foam, stringers rest of the plywood) or do I strip it sell off everything and look for a another boat.
Do the gutting and slab some wood alongside the stringer to reinforce them?
What about using composite material instead of fiber glassed wood?
If I do the area between the hull and the deck. What about epoxying a sheet or 4 of PT plywood and then paint them with Herculiner?
Money is an issue. So it will take time to do it all. Currently unemployed so I have time. But no garage so everything will be outside in the weather. I do have a tarp big enough to cover it.
The Engine needs a water pump, the hydraulics are disconnected and the motor for the lift may be bad.
