Arriva 2050 5.0 alpha one best prop??
MikeyArriva
Hey guys. Recently sold the Arriva 2000 with outboard and got an Arriva 2050 with 5.0 Mercruiser and alpha one outdrive. The boat came with 3 props, a 19p 3 blade aluminum, a 20p 3 blade and a 21p high five stainless prop. The high five seems to work the best but none of them jump out of the hole very quickly especially if there is a couple people in the boat. It really doesn't want to get on plane and I usually need to get some people to sit up front while I stand there too. When it does plane out I'm only reaching about 3800 rpm and approx the same speed. 38 mph. I haven't found many people with this boat in my limited time to get online but I assume it should perform a lot better than this. Anyone have any experience with this or know someone? Should I go with an even smaller pitch? I'm surprised that the 21 5 blade is better than the 19. I'm looking for good response out of the hole more than top speed but figure this boat should be a rocket. Any help would be greatly appreciated thanks
Starcraft5834
you need a prop that's going to get you to your recommended WOT range.. 4500-4800.. assuming your engine is not ill, you report the 21p works the best?? 3800 top end is not best.... best response out of the hole will be a 4 blade... in correct pitch... I'd look at a 17p 4 blade if I were you....
Mikey, you do realize this is a duplicate post thread
MikeyArriva
Thanks I will look into a 17p I'm used to my 150 outboard and the 19 was as low as I wanted to go with that so I wasn't sure. And I apologize about the two posts I did this on the iPad and it kept saying error and couldnt send so I did it again and now there is apparently two. I will try to remove
steelespike
Your 38 mph seems reasonable for 3800 rpm.
At 3800 you have to make up about 1000 rpm really not practical with a prop. Boat should just about fly out of the hole and I would think 50 would be easy.
The first suspect is the motor.What is the age.A compression check would help tell about the condition of the motor.
Some easy checks:: a plug wire may be off or crossed with another.Throttle may not be opening all the way.Perhaps a choke or primer failure.
Maybe a defective or fouled plug.
theBrownskull
A 17p sounds about right. I would try to find a dealer that lets you try the prop before you buy it because every boat is different. I have been there and done that and still trying to sell the extra props I have. :facepalm:
MikeyArriva
Awesome. Thanks for the info. I will check over the engine and see whats up and if it checks out I will try the 17p. Will let yas know on wed or thurs when i can head back up there. And thanks for removing my other post.
