Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Read This First!!
This topic is closed.
This is a sticky topic.
  • Read This First!!
    ESSENTIAL DATA REQUIRED
    When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
    1) Performance issue you are trying to correct.
    2) Current prop manufacturer, model, aluminum or stainless as a minimum.
    3) Current prop diameter and pitch (required).
    4) Wide open throttle RPM and speed with an average load (very helpful)
    5) Engine/drive make, model, year, and HP
    6) Boat make model, year, length and weight
    The below link would be a much more thorough list of data to provide if you're looking for detailed performance numbers,
    http://forums.iboats.com/prop-questi...ml#post2336620
    sigpic
