Re: Armstrong Bracket/Engine mounting question??
Ok. Some more rpm wouldnt hurt. I would try to gain some with propeller lift rather than drop a pitch but if we reduce the slip % you may end up with a 17". <br /><br />I would look at the Merc Mirage Plus in a 3 blade. They have a very large diameter that I think you could take advantage of. <br /><br />In a 4 blade I would look at the Turbo line. The Ultima 4 has a big diameter, good blade area, nice rake angle and extended cup.<br /><br />The only way to know is to try one. Your dealer should be very willing to help you test one since you will be buying one from him.<br /><br />Let us know how yu make out.<br /><br />Good luck!
