fowl intent
- Feb 17, 2003
- 39
The boat is a 26 foot SeaSport, 3400# deep v, with a factory mounted Armstrong bracket. The Merc 225 EFI is mounted to the bracket with only an additional 3/4" or so for downward adjustment. As it is presently mounted the cavitation plate is a full 6" above the lowest point of the v hull. Is the very lowest point of the hull the reference point? If so, then it would seem that this is a design flaw, unless the bracket was designed for a long shaft (if there is such a thing in a 225 hp). The only way I see to lower the motor more than 3/4" is to have someone cut the top 2-3" of the Armstrong bracket, but that still wouldnt get the cavitation plate flush with the bottom of the hull. Does the fact that the motor is actually mounted on a bracket some 2+ feet behind the transom change the standard rule that the cavitation plate should be even with the bottom of the hull???
