Re: Arkansas Traveler
Hello again Ed. If your boat is rated for a 25 hp, it can handle it. With a light load, you might get close to 30 mph with a motor that size, which is pretty dang fast on the open water in a small boat, and 30 mph on the water "feels" more like 40-50 mph
A tiller motor is simply one where the steering, throttle and/or gear shift are controlled using the small arm that comes off of the front of the motor (like on my boat), whereas other boats use a "helm", or control station, with steering wheel and throttle/gear shift control mounted to a console in the center,or side of the boat (think bass boat). Generally speaking, smaller motors <50 hp tend to use tillers, while large motors tend to use helms, but there are exceptions to the rule. In fact, nowadays you can get 5 hp motors with controls and/or 150 hp tiller motors. One isn't really better, or worse than than the other. It's mostly a matter of cost, space and use. I like to keep things simple, so a tiller works best for me. Plus, it lets me sit, stand, or move around as I like. It's also a lot cheaper and easier to maintain than a helm set-up. Here's a link to a vid of some boats using each set up. You can decide for yourself which you think you might like better. Bear in mind that because of your boat's age, the engine rating assumes that motor is/was a 2-stroke, which are much lighter than their modern, 4-stroke cousins. As a result, while your boat is currently rated for a 25 hp, 2-stroke it could probably only handle a 10-15hp 4-stroke, which would weigh about the same. I think you'll find that most folks like vintage, 2-stroke OMC (johnson/Evinrude) motors for the reasons stated above. However, some lakes do not allow 2-stroke motors anymore, so check your local regulations.
Here's a vid of a "gheenoe" with a tiller motor and grab bar (aka "sissy bar"). It's a very popular set up here in FL where folks run in super skinny water and want/need as much visibility as possible. This is how I have my boat set-up and I love it.
Custom Gheenoe boats flying by - YouTube
Gheenoe Classic In Action - YouTube (another tiller skiff in action. the platform on the back is for standing on and poling from in very shallow water)
Sea Foam Green Tiller Caimen - YouTube (another fancy skiff using a tiller/grab bar set up) (you can also see in the intro to the vid the different configurations available with or without a console)
Here's a vid of the same boat(s) with a helm (ie control station) rather than a tiller. As you can see, the captain has to pilot the vessel from the helm at all times, which limits his ability to redistribute weight as needed, but a helm does provide a nice place to mount any and ll electronics and navigation gear.
Four Custom Gheenoe Lo Tide 25s Running the St Johns 07302011 - YouTube
Kyle Got His Caimen....mov - YouTube
