BoatNoobie
- Jun 17, 2009
- 314
Re: Are you suppose to tow with the motor.
In my Mercury manual, it says to leave it in gear b/c motor might start in neutral...
I don't understand this one. The driveshaft that the impeller is on is also hooked to the engine. With the shifter in neutral all you are doing is disconnecting the gears from the driveshaft. The spinning prop does not do any damage unless you have a bunch of fishing line or something like that wrapped up around the prop shaft.
