Are Wal Mart OMC style tanks any good?
SeaMasterZ@aol.com
Ive heard they have good prices, saw the tanks but didnt price them, but they look new and shiny, lol, but are they any good? gotta be a few wal martians up on what they stock in the marine section!
foxjohnc03
Re: Are Wal Mart OMC style tanks any good?
Have two of the 6 gallon tanks in my fishing boat. They work fine but I did have the plastic fitting that you screw your OMC connector on crack in the center. Probably just tightened the fitting down too tight.
rolmops
How wrong can you go for 13.50?
papasage
i have used wal-mart tanks with no probablem,<br />papasage
clanton
Pickup tube should be checked for size, and being to close to bottom of tank, for proper fuel fuel. Some plastic tanks have 3/16 fuel pickup tube, not large enough for most outboards.
mnkelsner
I just got two new plastic tanks from Walmart, (ATTWOOD Brand), they seem to work well for my 1986 70hp johnson. I bought a new OMC fuel line with primer and OMC adapters (also Attwood) for the tanks. It was $35 all togeather and seems to work just fine.<br /><br />My old tanks were ok but the neeed new rubber parts and filters as age had taken its toll,(I would lose power at the motor occasionally and it looke like a bunch of crap was makin its way to my fuel filter in the motor, after cleaning filter the problem seemed to go away for a while, so I decided to eliminate the fuel line as a potential cause of my problems.) The local marina probably could have sold me the replacment filters and caps/guages to fix my old tanks them up but probably more than $35. <br /><br />The only problem I have with the Walmart tanks is they are too small for mixing gas seem to be 6g exactly, my old tanks were 6.1 or 6.5, so now I only mix 5g at a time. The new tanks are transparent enough to see the fuel level so you dont have a guage on the cap.<br /><br />Maybe it's better to mix in a seperate tank ? (any comments ?)
rolmops
Both Wall and K-mart carry a plastic measuring can that has a scale on the side which for 5 different mixes tells you how much oil to mix.The thing holds a quart.<br />Instead of amount of oil,it reads amount of gallons.You filled 5 gallons,you fill oil up to where it says five gallons and there is your mix amount.Add it to you tank, end of story.No more smoke stack,no more worries about too lean a mix, and unlike a VRO it always works. All of this for two dollars.
sharkcat
Only if you have a walmart style johnson.. :D :D get a case of beer bury that thing & buy a merc :cool: thenyoull really have something to moan about..lol
