are replacement OMC Cobra drives still available?
mlrman
Hi, I am looking for a used or remanufactured OMC Cobra 800 outdrive. Can anyone point me in the right direction? I have searched and called many boat salvage yards so far with no results. Thanks.
Blujay96
Re: are replacement OMC Cobra drives still available?
What year are you looking for.
HT32BSX115
Howdy,
Well, Google is your friend I suppose,
Affordable Reman OMC Cobra and Cobra SX Sterndrives by Drivemaster Marine
OMC cobra drives
New - Used Outboard Motor Parts - Marine Parts Outlet
OMC Sterndrives - OMC Outdrives - Cobra Sterndrives - Crowley Marine
Stern Drives: Marine Engines: JASPER
Plan on spending possibly MORE than your boat might be worth with the "new" drive on the back.
An alternative might be an SEI drive,
Sterndrive Engineering: Conversion kit
Good luck,
Rick
mlrman
Hey thanks for the replies! I don't know where I got the "800" from, it is definitely an 1991 OMC 4.3 V6 Cobra. The model off the outdrive data plate is 987122. Since my original post, I have found a couple outfits (iboats is one) that sell remanufactured units based on a core charge. I will keep an eye on ebay, and also check out the links you all supplied.
Thanks again.
Bulbash
I know GLM still make some of the cobra drives depending on what gear ratio you have
