are QL82YC the right plug for 1990 90hp?
powerwagon360
my 90 model 90hp seahorse has champs QL82YC in it and i want to know if thay are ther right ones? both My 1978 rude and 76 johnson 115s has QL77JC4's? i figerd that the 90 vro would have the same plugs as the 115s?
seahorse5
Re: are QL82YC the right plug for 1990 90hp?
The QL82YC is the wrong plug. It has an extended nose on it that could hit the piston.
The correct plug is a QL77JC4 or the QL82C. The QL82C works great on older motors as it does not foul as easily, which was a problem with QL77JC4 plugs.
powerwagon360
:eek: no crap. well do you think i would no if it allredy messed it up? i just got the pontoon this 1990 90hp is on and have not looked at the plugs till today. It runs like a dream.it will lay you back on the 24' toon :D. is the the first # in that plug the heat range?
i went to ngk in my 18hp and 25hp johnson's and it made a big difference in start up(pull start). should i go ngks in the 1990 90hp vro?
