- Apr 17, 2002
- 71,491
Re: Are newer boats faster?
Gear Ratios.....<br />Merc. is Still using the 1.98/1 in it's outdrive for the GM 4 bangers..... That hasn't changed....<br /><br />If you installed that little Gem in the link, I'd think you'd Need Atleast 4" more prop......<br />Depending on the pitch you're turning now, You Might have to jump up to a 1.84/1 ratio outdrive gears.......<br />'Course I'm Guessing you've got an OMC, So, I don't know what your options are there......<br />
With out a Doubt, The Biggest Bang Available Anywhere for a 3.0l..........<br />With the Right Tuning, You Might approach 180hp or Better........if it's installed it means generally more umph
