Are MerCruiser 470 4 cyl I/O's Any good?
D-squared
Hi, I am looking at a 26' Cruisers Inc 266 Vee-Sport Sunbridge boat that has twin 4 cly 170 hp Merc I/O's on it. The port engine has been rebuilt with only 15 hrs on it, the starboard engine has 900 hrs. The very fact that the starboard engine has lasted 900 hrs says that these engines will go the distance if maintained properly. Am I being nieve in my assessment of this motor?
Are these MerCruiser 470 4 cyl I/O's - Any good?
Thanks, Don
Re: Are MerCruiser 470 4 cyl I/O's Any good?
Ayuh,.... If you don't already own it,.... Don't buy it......
The 470s were a Bad Idea from Mercruiser,+ they figured that out after only a few years,....
They haven't been built for close to 20 years,+ parts are getting scarce....
And,.....
A Refit is usually a serious Problem, because the drives are usually installed Too close together to go to a V-motor,+ Larger In-lines are not used anymore either....
Keep Looking,..... There's Plenty of boats out there Without this Handicap......
JustJason
skip this boat.... and any other with a 470..
Haut Medoc
One 470 would be bad enough, but two?......:eek:
Move on, there are a ton of boats out there.....;)
TilliamWe
Banned
I agree with all above. And unfortunately, you see a lot of those in twin applications.
The problem is, what fails on one fails on all of them. That starboard motor is gonna go bad soon, if the port side just did.
Walk away from the boat, quickly, and don't look back.
dcg9381
I believe this motor used a head from a 460 ford, correct?
It was common in a few of the larger Glastron / Carlson twin engine boats. Might check with the guys that own them - there are a few "classic" Glastron forums online.
D-squared
Thanks guys! Sound like you-all saved me a whole lot of greif. Don
Haut Medoc
Your wallet will love you for this decision.......;)
