Are bellows ground straps necessary?
otterby
I forgot to reattach the small ground strap under the hose clamps when I put new bellows on. Are these even necessary? Why would you need to ground the hose clamps?
Don S
Re: Are bellows ground straps necessary?
It doesn't protect the bellows, it protects the clamp from corrosion. If you have a trailer boat and don't keep it in the water after use, it's not a big deal.
