Re: Are 4 strokes as tough as 2 strokes?
what200, <br /><br />
"mis-information"?? <br /><br />You didn't do a very good job of pointing out any of that misinformation
<br /><br />
"I actually kinda agree with you on this one, but that is why I disable oil injection on every outboard I own."<br /><br />Disabling the oil injection system on all of your 2-strokes reinforces my comment. I don't see any misinformation there.<br /><br />
"I think to say that fuel efficency is biggest predictor of engine life is incorrect."<br /><br />Well, I'm glad you said it because I did not. I guess that makes it
your misinformation, since you don't seem to understand efficiency of engines.<br /><br />Fuel is only half of the efficiency concept. The other half is how much power is produced. So I'll say it again....<br /><br />"There is a correlation between efficiency and engine life. An engine that works less to provide the same efficiency will generally not wear out as soon."<br /><br />
"I believe that displacement is a better predictor. GENERALLY SPEAKING The more HP you get from a given displacement, the less durable it will be."<br /><br />Exaclty. 2-strokes are smaller displacement, higher hp engines, and according to you this makes them less durable.<br /><br />
"BUT the examples you give are misleading. you said, "200 hp EFI is at 3130 cc's and the 4-stroke 200 EFI is at 3352 cc's" <br />You picked one of the lowest hp to displacement ratio large outboards out there.'<br /><br />What's misleading was Franki's post about 4-strokes needing
twice the displacement to produce the same power as a 2-stroke. I easily proved that wrong, because it's not true. Sometimes the truth hurts. It would be
your misinformation to say that since the 300 hp Merc is 3L that it would take a 6L 4-stroke to equal that 300 hp.<br /><br />
"but I'm not so sure of your conclusions that hurdles of implementing DFI technology is the cause of the troubles that some people have had."<br /><br />Excuse it for quality control or whatever you want. DFI technology came with many pains, some were the most severe to ever hit the marine outboard industry (Ficht). It was uncharted ground. Whether it be HPDI, Optimax, or Ficht, they all have had more than their share of problems, at least compared to EFI or carbed 2 and 4-strokes. My point was that it's the direct injection theory and it's critical operation and tolerances itself that has caused the technology and quality control problems.<br /><br />
"I happen to know of a mechanical fuel injection evinrude looper that is very fast. I'm sure it is a pain in ass to setup but not impossible."<br /><br />It's unclear what "misinformation" you are arguing here or what point you're trying to make?
My point is that without electronics today's direct injection would be all but impossible. Was it that hard to understand?<br /><br />
"In fact, on Mercury's racing inlines the motor often had 3 short megaphones coming off of the exhaust port; very little tuning there."<br /><br />That's because they're run at WOT while racing. Not idle, midrange, or cruise rpm. The "megaphones" do nothing for the entire power band...only top end. Again you reinforce my point for the need of a variable tuned exhaust with a 2-stroke. Besides, you're talking racing. Don't "mislead" the readers here that our 2-strokes perform best without tuned exhausts. They absolutely need them. 4-strokes don't.<br /><br />
"You also have referenced scavenging several times, but 4 stroke scavenging is not all that unlike a 2 stroke."<br /><br />Yea, so where's my "misinformation"? Obviously all engines scavage. Please don't "mislead" readers here to believe that a 4-stroke scavages like a 2-stroke. 4-strokes control the valve timing. 2-strokes do not. That is, 4-strokes can open and close valves whenever they want to, independent of piston position or combustion timing. A 2-stroke can't, because the transfer ports are dependent upon piston position and combustion timing.<br /><br />
"marine engines in general have to produce greater power to maintain a given speed when compared to automobiles."<br /><br />Work is work. Whether a 250 hp engine is producing 250 hp in a truck or boat, they both do the same amount of work. If that work is displacing air and pavement or water it doesn't matter.<br /><br />
"But I don't see how age does not affect reliability. Even when not in use, things go bad like electronics, gaskets, rubber seals, etc."<br /><br />Yes, but that would be true for all outboards, whether 2-stroke or 4-stroke. The seals, gaskets, and electronics would have equal chance of needing repair due to age. The original post was about actually
running the engine, not storing it. Here, time or engine hours is what matters, not how long it sat in the garage. Again, the point is that some people claim their outboard is 50 years old blah, blah, blah, when in fact many probably have more hours and wear and tear on a 10 year old outboard.<br /><br />Misinformation? Hypocricy is alive.
