Re: AQ270 hub shaft
More info on the long vs short shaft and hub.
I have been doing a lot of searching through Volvo information and just general internet info. Seems there is a short shaft and a long shaft on the single prop drives. But that is all that's known.
The problem with the information, is there is no way knowing which drive uses which shaft. No part numbers, no VP info, just some diagrams like above showing the different lengths.
Could be one is from really old 200 drives and the other is newer. Have no clue since VP never mentions it.
The difference between the long and short shafts is the same as the thickness of the line cutter spacer. So maybe the different lengths are due to adding the line cutter in newer drives and Volvo needed some more room.
Along with that wonderful information is the fact that the manual picture I posted earlier doesn't really give quality info on the prop hardware, and the differences about the drilled and non drilled propshaft hardware. Found the info that shows that.
