AQ131D out AQ145A in
user-name
Re: AQ131D out AQ145A in
I"m off to Harbor freight
I'm borrowing my neighbors dwell meters 2 Now I have 3 dwell meters.
ALL 3 have a different reading.
I'm not giving up hope yet.
BTW out of the factory Glasply Did put 120hp mercuisers & Volvo Penta AQ140 125hp in these boats
user-name
The towel is acting as a choke. Those carbs have no choke. Now you have discovered a new cold starting technique!
Your compression numbers sound good.
I wouldn't hesitate to pick up a rebuild kit and go through the carb.
So you like my choke........ I love the K.I.S.S method.
Carb kit where Please
user-name
Well I went to HF got a automotive meter dwell tack temp ETC ETC
Dwell was out it was 47ish
Set to 62ish started Ok It was warm for earlier gave it some gas got her up to 3600ish POOF
I'll check the BT
crankshaft TDC pull 1CYD both valve should be up ( Right)
user-name
That was weird
I thought I ran out of gas.
hooked up the boat tank wouldn't start primed the carb no start.
Thats when I fingered the TB jumped
ruffly 45 minutes later
Just when out to hook up battery charger looked at the key said why not cant hurt,,,,,, bamm fired right up.
Dwell is off a we bit forgot the number. Got to get 62dg in my head and remove the 31
Tomorrow or whenever see what happens.
captmello
Wow, what a flurry of events!
Don't forget to reset your timing whenever you adjust the dwell.
Maclin
...I don't think I have ever seen a dwell meter that reads in percent.
I have an older (bought in the late 70's) SunTune inductive dwell/tach, looks like a small multimeter, I think i got it at Sears. The needle reads percent, and there is a conversion table on the back. That is the only style I had seen back in the days when this thing was new, but I was already "old" by then :)
user-name
Reset timing Noted Thank you
I probable would have for got to do that.
Sidenote that AQ145A is looking better,, That sea water filter don't interfere with the DIST like this motor
Mistake T-State housing not SWF
Robj
I run my timing at about 9 degrees, performs better with a bit more advance.
