Water-is-life
- Mar 1, 2012
- 17
Ok, I bought a 1985 Bayliner Capri 19ft at the end of last summer with the aq131a /275D outdrive for $3200 in great shape. It was running a little hot but never got what seemed to be too hot so I took it to the boat mechanic. I found out the transom was rotten and it needed a carb rebuild and decided to have them install a thru-hull water intake to fix the cooling problem. So after 5 months and 1800 more dollars getting the transom replaced and carb rebuilt, I got it back last week. Took it out saturday on the Tenn. river here in Huntsville and it ran like a dream, had a great day on the river. Hauled it up to Tims Ford Lake in Tennessee Sunday and after warming it up, started heading to a cove to meet some friends... cruised at about 3300-3400rpms for about 8-9 minutes, engine sounded great, then BOOM. Out of nowhere, with all new fluids, and the mechanic saying entire engine was in great shape, it blows up. Got some pictures for ya.
Both sides of the block have huge holes on the cylinder closest to the transom. The starter blew off and all the oil gushed out. I really don't know what caused this, it wasn't running hot, oil pressure was good, it never gave any signs. I can see a bent rod, not sure about the crank. You can see all the way through each side of the block .
I really hate to just be out of $5000 and a boat. I really can't afford much and have been reading it is possible to swap the block from a volvo car with the b230 block. I've been searching the forums but can't seem to find a few clear answers. Should I just swap the block and use my head? Would any volvo with an early 80s b230 block work or what type of car would have the compatible engine? Could I use the auto crank and pistons with my head? I know to make sure I find one with the distributor in the block, and swap over all the other marine parts. Does the marine version have a larger oil pan?
I did read the other thread on here about swapping the entire engine with one from a 92 volvo 240.
http://forums.iboats.com/showthread.php?t=503981
Would this be easier just using the entire engine out of a 240? and would that work with the 275D outdrive? Or what would be the best auto engine to look for that would most closely match up using my outdrive and parts?
Thanks for any help!
