aq130c to a 280 OD Matchup
B McCally
I've got a running aq130c/270 in a rotten boat, and I got a firm boat with a crap aq130d/280 I would like to match the 130c to the 280 OD. Is she gonna just slide right in or are there any technical complications. The motors look about identical except the D model has a sea water strainer.
Don S
Re: aq130c to a 280 OD Matchup
Shouldn't be any problems.
billbayliner
The rear engine flange on both AQ130's should identical, and should fit either flywheel cover and drive.
The drive ratio will be 2.15:1 for this motor.
