New here. Thanks for any info.
I just bought an 85 2150 Bayliner that had been sitting for six years. The PO said that the motor was rebuilt 15hrs before sitting(I have receipts). I was hoping that with Engine Release and some time I may be able to free it up. No luck so far. I have been using a breaker bar/impact wrench on the crank. I have removed the starter, head and pretty much anything else that was bolted on. The pistons and cylinder look alright, so I am not sure if that was even the original problem. The head and the intermediate shaft all turn no problem. The tensioner bearing was seized, but it is off now.
I am thinking that it must be the main bearings. Can they seize from sitting(with oil) or is the PO full of it? Before I pull the motor for rebuild, I just wanted to post to see if there is anything, that I could be missing, that could be causing this. Also, there was oil in the bellows, but no water, so I don't think it is the rear bearing. Is there a similar bearing on the front of the engine that could be frozen?
Although, at this point I am almost committed to pulling the motor.
Thanks,
Nathan
Thanks,
Nathan
